By accident, I saved an sdb.xml file (Sony Channel Editor file) to an USB stick registered to Sony Bravia 2015 for recording purposes. I downloaded CX File Explorer and FX File explorer from Google play, neither of them offers file deletion in their smart TV compatible version. How can I remove this file from the registered USB?
@jcsaba I'd suggest you connect the USB to a laptop and delete the files as I don't think the option is available on the TV.
