Hello,
I have a new Sony Bravia XR-55A80L and I'm using the "simple" remote control (few buttons). It has a light sensor, but the backlight doesn't work. What do I have to do to activate the backlight feature?
Thank you!
Hi @augmatic If the TV should come with a backlit remote, then take it back to the Retailer and demand a replacement that works properly. They probably swapped your remote for another customer!
Edit: I have just checked mine, it doesn’t have a “light” sensor, it has a “movement “ sensor. It lights up when I move it.
Hi @augmatic, this model isn't supplied with a backlit remote control. The backlit controller model number is RMF-TX611E, is this the one that came with your TV?
HI
I have the same issue of the backlight not working.
Any answers to resolve yet ?
Thanks
What TV do you have?
Do you know the model number of the remote control.
Take the battery cover off and look at the label at the bottom left you should see the model number,
my XR42A90K has the RMF TX 9000U backlit remote.
Try pressing and holding at the same time the Volume - (minus) button and the Home button for two seconds
the microphone LED should blink, after two seconds the Backlight should either be activated or deactivated.
Hi
TV is just out the box
Sony Bravia XR-55A80L and Remote is TX810U
Tried the holding down Volume - button and home for 2 secs but no LED lights up or backlight working
