Can anyone shed any light on what difference pressing the audio button on does on the remote control. Namely on the XF9005. Each press changes from audio A, B and Dolby digital stereo. Will A and B just be mono ?
Hello @anparnh55,
that depends on which audio-tracks the TV-channel you are watching supplies.
A would be "normal" stereo, B could be audio for hearing-impaired and the last track is self explanatory.
- Nic
Not right.
‘blank’ is stereo
A is mono something.
B is mono something else????
Section 6
found it!!! Bit vague.
