Hello
Sorry if this is a really straightforward question, but am looking for some help with recording to a USB hard drive from my Sony TV.
The model we've got is 49X8307C.
I tried a small usb stick (16GB) before I realised it has to be a minimum of 32GB according to the manual.
It comes up with a warning that recording is not available on YouView.
Before I go and buy a bigger external USB hard drive, will this work? If so do users think it works well - or causes problems? Is it reliable?
My other option is to buy a FreeSat TV recorder and use existing Satellite feed, but this would be more expensive for a reasonable sized box.
What do people think?
Any help gratefully received.
Thanks
Andrew
Hi Karorian,
We're going to look into this for you, and we will get back to you as soon as possible.
Thanks,
Sean Mc
