Just purchased a 49xf9005bu and daily have to add the WiFi password. The connect via wps never works.
Connecting to virgin wifi, no problems with other devices
any ideas?
Hi there,
Have you tried a factory reset?
Best wishes,
M
Have you try anyway to reboot the Router?
Manolo
