It is Very difficult to find the exact framerate a TV can show from the Hz number alone, so I'm wondering if anyone can confirm if this TV can actually show games at 60fps? My other 4k tv could only show 50fps, but that might be due to not playing around and finding the proper settings for it, like game mode. Still having my FPS max at 50fps would simply be a dealbreaker.
HDMI IN 2 / 3 support HDMI 4K 60p/50p 4:2:0 10 bit, 4:4:4, 4:2:2.
Manolo
Thanks for the quick reply
I'm not much into technical terms, so I'm sorry about my dumb reply, but does that basically mean - yes, I can achieve 60 fps on this TV through my computer and console?
There are no stupid questions. Yes you can get 60p.
For computers and consoles, HDMI 2 or 3 connections are better.
Manolo
