how do you set a program to watch later?From the guide choose pogram for later.if i press the OK button it goes to TIMER RECORD then SET TIMER EVENT.i dont want to record,just automatic change when program starts.I have a 2TB connected.
Hi there,
You may find what you need here.
If not hopefully a community member can help.
Best wishes,
M
Hi beerbarrel,
It doesn't seem that the reminder feature is supported. Only recording timers are available.
Regards,
Vanilla_
