I've bought brand new Sony KDL-43W807C and installed it without a problem, but it seems there are some issues. I've Virgin Tivo box, which I connected to the TV via HDMI cable. It shows my normal Virgin Media channels on input HDMI 1. So far so good, but when I try to enable YouView it can't detect any services, so I am stuck only with BBC Iplayer. I can't access ITV Player, or 4oD etc. I am not a techie, but managed to sail through various PCs and TVs without major issues. I've tried many things with that Bravia, but I just can't fix it. I feel the problem isn't that serious, but just can't find a solution. Can you please help me? Is the problem with the Tivo box, or some settings, or do I need some extra cables?
Thank you
Cool. Thanks for the update. At least it works, even though you will need to keep it connected.
