Tv 49XE9005 had problems registrating hdd (Western Digital 1 tb Elements basic storage).
Error message at end of registration was "can't register now. Try later" and no clue to what was wrong. After 4 hours search, buying new HDD, I finally found somewhere on the web, that disabling application "youview" could help, as it block pvr. It worked and solved problem.
You find youview under applications. Apparently youview is for the UK market, but still downloaded with the manufacturing installation for sale in Denmark.
Hi there,
Thank you for sharing. We will pass your feedback on.
Best wishes,
M
