Well I had the Oreo 8 update when I switched on the tv afterwards the tv just gone into a update loop and keeps trying to update and then shuts off constantly.
i tried all the reset options with no joy.
So gave Sony support a ring and answer “oh yes you have a problem you will have to get a Tv engineer to fix it as it’s out of warranty “ out of warranty by 3 months and it’s an update that you along with android sent out for release and then sod people who no longer have a tv they can use.
Well seems like I have to get it fixed and then sell ASAP unfortunately.
i have always had Sony as I believed they meant quality.....That seems to of gone the way Brexit is going.
Hi Simon,
Thanks for posting your feedback. Let us know if you need any more help.
Best wishes,
Ed
