Can not scroll back 7 days anymore and ITV 1 Hub keeps asking for postcode even though it has been entered. Are they both connected ? Had a 24 hour power cut at the weekend, not sure if relevant. On scroll back says no information, will scroll back for the current day but not previous days. Says software is upto date - TV is latest Sony 49" . Was working fine on scroll back (never previously watched ITV Hub).
It sounds like you will need to do a Factory Reset to have any hope of clearing this problem permanently.
Try one of those, from Settings, and see if the issue goes away or not.
Worked for me too!! Thanks
Perfect thanks this has been bugging me for weeks
How did you get a fix from eith Sony or youView
The problem still exists for me, I have used the advice above and it clears the problem for about one week then it comes back again, really fustrating as SOny supposed to be a quality tele!!! would really like to know how to get a formal response from Sony on the issue ????
Thank You so much, it has worked a treat.
Thank you so much. We have ITV hub again 👍
Extremely grateful to you. It worked a treat. It has saved my marriage because she can now watch Endeavour and Midsomer murders.
Thank goodness these posts stay up for ages (over a year) because your answer still solved my problem...brilliant thank you.
BTW the Sony Bravia TV I have is the worst TV EVER, nothing but one problem after another. No wonder it was in the sale!!
Thanks and kind regards
Dee
Brilliant it worked ! Thank you
so much ☺️
