after the Firmware update to vPKG4.550EUA on my sony tv kdl 42w655 TV restarts. Applications jou tube works poorly, blocks, what is the problem and how to solve
Hi there
Ive moved your post to the tv section. Hope you dont mind.
In regards to your problem, try performing a factory reset as this normally clears issues after a fw update.
