Hello,
I have had my TV for a few weeks and all was good until I started watching Vikings on Prime. The black levels are shocking when showing dark scenes. It’s like moving blocks of blacks. I have reduced the black level to 42 but you lose loads of detail!
i am on standard setting. The top one is from the darts (bit harder to see) and the bottom Vikings. Don’t know why they aren’t the right way up!!
any suggestions? Thanks
Standard is not the best setting on Sony TV . You should use the custom one unless you calibrate it.
Nonetheless if you care about blacks why did you buy an LCD TV?
Have always had Sony and was happy with it until i saw that. I’ll have a tinker on custom. Thanks
