Hello all,
I have Android 4K TV model KD-49XD7005 (I know it's not a total zinger).
What I want to politely ask you is...
The tv has shaft table top base stand like this one (see the picture below)
Now I want to buy a soundbar (Sony HT-X8500) and put it in front of the tv. But the current default base stand is too sticked out and interupts placing the soundbar. So I really want to replace it with different base stand with two separate wider spreading legs (like these ones of model KD-49XF7005 - see the picutre below)
Do you know if it would fit? Do you know where I can get/order the part? Any other advise or recommendation?
Thank you guys for any answer.
All the best from the Czech Republic.
you cannot swap the standard stand of the tv, but you can find anywhere a new stand that has VESA compatible connection with your tv
