annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Pin
profile.country.GB.title
Ingchr1970
Explorateur
Pin
Hello. I need too prevent my son from using the tv. Instead of looking for a job. So can I put a pin on it to prevent him from using the TV at all. If I can how do I do it?
3 RÉPONSES 3
Sean_Mc
Moderator
Hi there,
So I can look into this for you, can you let us know the full model number of your TV?
Best wishes,
Sean Mc
Ingchr1970
Explorateur
Hello Sean
The model number is KD-55xe8396
Sorry it took so long too reply
The_Black_Rose
Spécialiste
Hi Ingchr1970,
I've just had a look into the manual, I believe you can set up a pin for almost everything.
I recommend that you check this link: https://bit.ly/2RYD3QX
Cheers,
The_Black_Rose
