I have been playing with the different picture profiles on my AG9 and i have some questions i hope can be explained to me.
My impression of picture profiles were that they basically were the same. They just had different settings. But i can set the settings for the "Vivid" profile and the "Standard" profile to be exactly the same and the "Vivid" profile still has a slight dim compared to "Standard".
Same thing with "Dolby Vision Bright" and "Dolby Vision Dark". Same settings, but "dark" is actually darker.
I am quite sure the settings are the same, so i was wondering if picture profiles have som hardcoded hidden settings do differentiate them from each other?
Hi again, Whitedear,
I will see what I can find out about this too.
Thanks,
Pascale
Hi WhiteDear,
I'm sure that the engineers programmed the mode to have different effect, that can't be achieved by manually adjusting the settings.
Cheers,
The_Black_Rose
