We've just brought this TV which apparently has the capability to do Picture and Picture, but we can't work out how to get this to work and theres no mention of it in any of the manuals we can find.
Please can someone put us out of our misery and tell us if it is possible and if so how to do it?!
Thanks,
Zeetha
Hi @zeetha,
https://www.sony.co.uk/support/en/article/73499
Picture in Picture/Picture and Picture
This feature will be available before 24th December. However, due to the technical complexity implementing this feature, the final release date(s) stipulated on our support site may be subject to change. PIP/PAP will be available for HDMI/Tuner combination via the latest firmware update.**
** Browser/Tuner, USB Tuner, Tuner/Tuner combinations are not available with this function.
Manolo
Hi @zeetha,
Manolo
Ah I see, thank you for the information. We shall try it again after then!
Thanks,
Zeetha
