Hi
i have Sony Bravia tv kdl32wd75x. Wanting to watch tennis using sport screen, nothing happens when I press the options button. It was working fine last week! All other buttons on remote work. I can’t see any other way of getting to screen mode selection via any other menu either! Any ideas? Thanks
Hi Clecky,
If the TV is connected to the internet, you don't really need a USB stick. You can download the update onto the TV directly by pressing on Home - Settings - Customer Support - Software update.
If a message came up saying that the software is up to date, go back to the system information page to view the version installed on your TV and compare it to the one mentioned in the link, if it's the same, then the software is already up to date.
Cheers,
The_Black_Rose
