Hdmi ports 1 and 4 only output left audio
Tried different sources and cables and the outcome is the same, only left audio.
Hdmi ports 2 and 3 output left and right audio.
I'm thinking it's happened since the update as never noticed beforehand.
Sound out of the right TV speaker / audio out is the left channel.
What firmware version does your TV now show ?
6.0.1
Thanks.
That seems different again. Mine is showing PKG6.0614.0004EVA and its supposed to be V6.1004
I guess you've seen the other major problem threads relating to Android updates. Hope this one isn;t going to go the same way.
