Hi all, new to the forum have decided to use the programme guide with free to air and streaming channels works great no complaints but when browsing through the guide and click a channel I have to wait like 10 seconds for the event info to load before I can click view anyway to just disable this pop up and go direct to a channel while using the guide ?
Hi there,
Welcome to the community.
Which product do you have?
Best wishes,
M
Hi thanks for the reply sorry it's a KD-49XD7005 and im using the built in guide and browsing through I have to press the middle button then I have to wait for the the info to load before the view button can be selected and I can enter the channel I'm trying to disable it so its just one click.20180704_133648.jpg
Hi, So can you help ?
Hi l0stie815,
This message is normal with the TV's guide and I think there is no way that you can access the channel without passing by this window.
Cheers,
Almou_10
