Re Song KD48A9.
Not sure if this is a malfunction or operator error yet!
The TV shows a warning that automatic timer switch off will happen unless a remote button is pressed.
Several times whilst streaming material I have responded to this message by pressing the centre button, it seems the most obvious one to press. The result being that the streaming is interrupted, paused I think.
Is this normal, a malfunction or my error?
Yeah, that could be seen as you pressing enter, which will stop the playback or pause it.
You have a multitude of other buttons, volume, features, like subs, etc, or any you never use or have a function that you need.
