Was told by Sony salesperson in John Lewis that upcoming Sony software update will include now tv app - any idea when this is coming?
Now tv is an app and should be delivered by Sky (the developer) onto the google play store in order to be usable on Android TV. As of now in any case NOW TV is usable via any smartphone using casting.
I think John Lewis may have missinformed you, as I didn't think (at least the last time I checked) that Sky planned to release the App on Android TV.
It would be worth contacting Sky for the actual facts to be honest although, as rooobb says you should be able to cast from your smartphone as a work around.
😞 it was the Sony rep in John Lewis who provided that info....
https://community.nowtv.com/t5/Off-Topic-Chat/Android-TV/td-p/502242
looks like chromecast doesn’t work for now tv...
Sorry but I do not understand what you are looking for.
Now tv is advertised has compatible with chromecast . Your tv has chromecast inside. If it doesn't work you have to complain to sky. I tested it myself some 2 years ago and it worked.
Do you want me to buy one to test it for you?
I find your attitude quite offensive...
The point of a forum is to compare knowledge. I created this thread to help clarify if others knew when / if now tv software was going to be included in this product. You mentioned chrome cast but I have found numerous posts, as shown, which state this doesn’t work...
if you can’t comment in a polite and non-patronising way, as an ‘expert’ i suggest don’t bother!
