Wanted to get my android mobile notifications to come up on my Bravia Android OLED. Have read about the App called "Notify Bravia" but it doesn't appear to be installed on my TV - is this not supported in UK? Is there another way of doing it?
There is not such an app deployed by Sony on its Android TV, but there are on the market that you can install such as https://play.google.com/store/apps/details?id=de.cyberdream.androidtv.notifications.google . I didn't try it myself since I do not see any use, but you can try and give us a feedback
Hi Mike,
I've not heard of this app 'Notify BRAVIA'. It might be best to get in touch with the support team here who will be best to advise you further.
Best wishes,
Sean
