No Video on Sony Bravia internal tuners - Video OK on STBs
My Sony Bravia KD-55XE8596 no longer has video when using the internal Terrestrial and Satellite tuners, just a blank (black) screen. There are no audio issues. When using a built in iPlayer, all that can be seen is vertical lines. Menus and EPG are viewable. Thinking that the issue was with the backlight; rebooting and factory resets worked for a while, but no longer.
However, I have no problem getting a picture when I use either an external tuner, (e,g. Freesat, Freeview), or a Blu-Ray player with HDMI connections or an external HDD with AV component connection.
Any suggestions for a fix is getting video when using the internal tuners?
Any help would be appreciated.
I think your TV is broken, and will need a repair.
If it is still under a retailer warranty, contact the retailer who provided it to progress this.
If it is out of warranty, or is under a Sony warranty, contact Sony to find your nearest Sony-authorised repair facility, and proceed from there.
Hey @Seano0083, check if your TV is running on the latest software version or not. the latest one is v6.7210. Also, have you tried a factory data reset?
Hi Piscie
Already tried the factory reset
Software version is PKG6.7210.0363EUA
Unfortunately the TV is now not switching on, but trying a few fixes, draining the power button, draining the remote and disconnecting from the mains for a while
Regards
Sean
Hey @Seano0083, you can try a forced reset. The instructions can be found here
If that didn't work, try reaching out to the Sony reps directly to arrange a service for you as it might be a hardware issue I'm afraid.
Hi Piscie
Forced reset didn't work, so brought it to Sony Service Centre who diagnosed a faulty motherboard.
At least the repair is economical.
Thanks for your assistance.
Hi Royabrown2
Brought it to Sony Service Centre who diagnosed a faulty motherboard.
