I reset tv to factory settings because after a new main circuit board fitted after only 4 months use. We could not get teletext which we look at daily. We do not need the internet at the moment so did not enable the smart tv option on set up. Should we have done this in order to get the red button service? I am baffled as to why it is not there.
I believe Teletext was axed due to its age some time ago.
Could you let us know if you're still having the same issue after updating to the latest software version?
This sometimes happens when a TV is not connected to the Internet during the initial rollout, but you can always use the Manual USB method.
Thanks. I put this question to Sony in an e mail. They said that the update has not rolled out to all areas yet but could try the download to usb method. I have put it on a usb stick but am reluctant to try that as I have read reports of tvs going wrong with this method. I have asked Sony about which areas are still to be covered and when that would be. They have not replied yet.
