- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
No Sound - Sony X900h & PS5
So as of today no sound is coming out of my X900h tv when using PS5:
- Sound does come out from other apps on the tv (i.e. netflix etc..)
- Picture is all fine
- I am using the HDMI3 eArc/Arc port
- the sound does come back if i change the HDMI signal format from "Enhanced format" to "Enhanced format (Dolby vision)" . however, this then means i cannot play my games at 120hz which is a big point of a few of the games i play
- I am running the latest firmware on both ( just checked there are no outstanding updates).
I have tried switching everything off, swapping cords etc but to no avail.
Any suggestion on how to fix this?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Use HDMI 4. The arc one is more for soundboard etc. Also long press the off button then click restart once you have done it. I use PS5 in HDMI 4. Never had an issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If possible please try to change the audio output settings of your PS5 (sorry, cannot verify if this is possible since I don't own a PS5).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I was under the impression that the 120hz only works on HDMI3?
Have tried the long press /restart to no avail.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is a known issue which Sony is already working on and you've actually stumbled upon the officially suggested workaround.
Also, both HDMI 3 and 4 support all of the gaming features according to Sony.
Hope this helps!
- JD
