Is it right that YouView does not allow you to set a programme reminder? Such a basic and essential feature should be provided on all modern televisions. Surely a flaw in the software that Sony needs to provide in an update.
Programme timer are not available as well as recording when youview is enabled. No update will fix this
It is like this since the first android tv model in 2015
