Just purchased the KD-65XG8796 and after ripping every bit of packaging apart, I cannot find the IR Blaster. I beleive it is supposed to be supplied with one. So if it is missing how do I get one supplied ?
@Captainkye wrote:Just purchased the KD-65XG8796 and after ripping every bit of packaging apart, I cannot find the IR Blaster. I beleive it is supposed to be supplied with one. So if it is missing how do I get one supplied ?
Hi @Captainkye
Looking at your “What’s in the box” on the specifications page, there is no IR Blaster included. Is there a connection port for an IR Blaster on the back of the TV? There doesn’t appear to be one shown in the manual.
As an example on my KD-55XE9305 the IR Blaster connection is found on the back of the TV.
