I can not find AirPlay on my set. Can I assume it is NOT compatible with the model in the Subject box?
Is there any work round?
Thank you.
Hey, it appears that your TV doesn't support Airplay, you can find the list of the supported devices here. You can get an Apple TV as a workaround as @Marino.Manolo said.
Thank you gentlemen.
Just make sure to check the specs before buying a new product to see if it align with your needs or not really.
Thank you.
