I have just bought the Sony KD-65AF8 Android TV. I am having quite some trouble getting it to output 5.1 Surround to my Denon AVR-1911 Surround Sound Receiver.
The receiver supports ARC so i have tried connecting them using a HDMI High Speed with Ethernet cable and enabling HDMI Control. It works just fine as i can control the volume from my TV remote and i can output stereo sound, but if i use any of the built-in Apps on the TV i am unable to output 5.1 surround. I have tried with Netflix, Sony Video App, Plex, Kodi and VLC. When i select an 5.1 Audio source there is no sound output at all.
In the display of the receiver it shows that it is receiving PCM signal. The only way i can get any audio is if i set the Sony TV to Output PCM. THen i get stereo output when i play any 5.1 Audio source.
I have also tried using Optical Audio connection with and without ARC. It makes no difference. The receiver keeps showing that it is receiving PCM and outputs no audio.
I tried fiddling around with the different sound settings on the TV, but i did not manage to make it work.
I know the receiver works because i can connect a Chromecast directly to the receiver and output 5.1 surround through that no problem at all.
However i really like the interface on the Sony TV's built in apps like Netflix and especially Plex. So i would like to be able to use it without having to connect a chromecast, apple tv or something like that. So i hope someone here might be able to help?
Thanks for your clear response and related notes. The background music during the setup is in stereo LPCM, however your AVR is probably up-mixing the signal to multichannel audio.
Do not change the TV settings during all your tests to anything other than the settings I listed in my previous post.
Keep us updated!
Cheers,
Dutchice
Hi @Dansn86,
Will it be possible for you to answer the following questions, so we can start to look for the root cause of your problem.
Report back and we will take it from there.
Cheers,
Dutchice
Hi @dutchice,
Thanks for taking your time to assist!
1: Just updated it to 6.5830 today
2: Problem has been there since beginning (bought TV 2 weeks ago)
3: I do not have any Analog/Digital broadcast channels.
4: I made the corrections below, but still with the same result. No audio when playing a 5.1 source. If i switch to stereo source sound is output.
Just a sidenote. I tried to factory reset the TV today after updating the firmware and i noticed that during the initial setup there was some surround sound music playing. First through the internal speakers and then after a short while it automatically switched to external audio system (guessing because of the ARC). Here it actually did continue with surround through my AVR.
Netflix 5.1. audio: No sound
Netflix Stereo: Sound works and i can actually set the receiver to output surround. However it does not sound like true surround
Plex 5.1 audio: No sound
Plex Stereo: No sound (I am not 100% sure the source was stereo. It said in the description though)
Keep us updated!
Cheers,
Dutchice
Hi @dutchice
Thank you for assisting. I finally managed to make it work!
Although i had already tried 2 different High Speed HDMI WIth Ethernet cables i decided to buy a new one and that seemed to do the trick. Even though it is the same type of cable "High Speed HDMI with Ethernet". So maybe there could have been something wrong with the 2 others i have tried. But now it works just fine with ARC, Dolby Digital and everything
Thanks for taking the time and getting back to us with your result. We are happy to hear that you are enjoying your new Sony OLED TV.
Give yourself a pat on the back, you've earned it.
Cheers,
Dutchice
