My BRAVIA XR A80K has NextGen ATSC 3.0 capability A few stations I receive are now broadcasting in NextGen ATSC 3.0
Is there any way to confirm or check or verify that my TV is receiving the NextGen ATSC 3.0 signal ?
Thanks
Hi @hasbeen
Are you in Europe? If not you may be better off using https://us.community.sony.com/s/?language=en_US
Hi @hasbeen
Thanks. Yup I joined that forum too
