profile.country.GB.title
Leearm1974
Explorer
Newly bought wd75
Hi. Purchased a new wd75 yesterday from currys and when got home no smart features at all other than the Netflix button which worked fine.  No other apps???   Took back to the store who advised there's been an update which has caused an issue and will be fixed.   Love the TV but can anyone advise if this is a known issue and how long may take to resolve.   Thanks
4 REPLIES 4
LightFoot
Specialist
Hi @Leearm1974. If you wanted a Sony TV with lots of Apps then you really should have bought an Android TV. Without knowing the full model number most (if not all) WD75 TVs are Linux. If you look at the forum for your TV there does appear to be a problem https://community.sony.co.uk/t5/other-tvs/bd-p/tv_en_1
Leearm1974
Explorer
It was sold as a smart tv with player.  Prime. Etc.   Nothing is working.  Thanks for the advice though
Leearm1974
Explorer
I player that is
Win_88
Specialist
Hi there,
I found this article on the Sony website with steps to fix this particular issue. Maybe you could try it and let us know the outcome here?
Win_88
