Hi all, I've recently got this sony XE9005 tv and noticed that it has this beta version of "TV Control Setup with Amazon Alexa", after the select your google account, it just got stuck at that screen.
I've actually added the sony bravia skill on the alexa app and logged in to my google account (same account as the one on my tv) and it's definitely linked.
What else can I do to get the setup complete? I've restarted the TV a few times.
I had it connected to my alexa until about two days ago Everything worked fine I try to connect now and get stuck in the same place as you I've tried everything except a full factory reset . Frustrating
Nickles soulution worked for me. Alexa has now taken back control! Now if I can only sort out hdmi control of external devices
This worked for me too, although I also had to clear all the existing data from the app. Thanks, it was driving me nuts!!
Hey there,
thank you for confirming the solution from @nickle182 worked - I marked his post as the solution, so other community members with the same issue find it more easily.
- Nic
