Version: V6.2858
Benefits and improvements from the latest update
* Selected Sony TVs (ZD9, XE94, XE93 and A1 Series) will support Dolby Vision with the software update to be rolled out in Europe within April, 2018. To enjoy Dolby Vision content, the video streaming app/service must support Dolby Vision. For more information, please contact the app/service provider. In addition, after the Sony TV receives the software update, devices with Dolby Vision playback (such streaming media players and UHD Blu-ray players) that are connected to the Sony TV by HDMI will also require a software update to support Dolby Vision playback through the device. For more information on the timing of an update to a particular player, please contact the player’s manufacturer.
Previous Benefits and Improvements
The following benefits and improvements are also included in this update.
Restrictions
Applicable Models
This information is for the following models:
For Amazon and Netflix no problems... It switch perfectly
Can we have different colors setting for different app with this update?
@gerald.ong77schrieb:Can we have different colors setting for different app with this update?
No. There are only 2 presets for apps:
Apps (Video): apply to all stock video apps (Netflix, Amazon, Video,..)
Apps: apply to all the other apps downloaded from the Play Store
One bonus of this new firmware is that the Satellite tuner works on my XE9005 even when Youview is enabled.
My set is running as 'up to date' on this firmware release, but the Sony Support app is telling me the latest available firmware for my set (KD-55XE8396) is v6.5603. Updating the set through manual or auto update and also USB stick fails to get beyond v6.2858 (v6.5603 is fully downloaded from support site to USB stick) Should I be asking Sony about this or is the latest firmware not fully rolled out yet ? Thanks...
USB update should work in any case. Did you follow the instructions? The pkg file inside the zip archive needs to be extracted to your USB storage. Is the USB storage detected when connecting it? Try to reboot the TV by long-pressing the putton on the remote with the USB storage plugged in. Update should start automatically after boot.
Yes the update appears to perform as expected, the USB stick is detected and system firmware update begins. The problem is that once the process has completed and TV rebooted, the firmware does not roll on to the new version.
