Today I can see a new firmware is available through TV settings.
But, I do not see this available for download and install from usb.
KD-55X8508C
Hi there
Your speedy gonzales today
Sony's announcement is coming !
I do this Update now !!!
Removed all HDMI's
Unpaired Bluetooth's and turned OFF every bluetooth device in home
Removed USB external keyboard
and..........started to pray
My update has just been completed - didnt unplug anything. Seems to have gone smoothly. Although im going to reboot tv - as i think its best to.
How is it? What's new?
Completed succesfully. Installation lasted more than 30 minutes.
Everything seems OK.
What remains unsolved and new issues:
1. Slow response in Digital Adjustments and Satellite Programme List Edit .
2. After search, Satellite Channels are placed again over 101 .........
3. YouView appeared in Settings-Apps-Running apps but is not supported in my region....(the app does not exist but runs in background...)
4. Programme List Transfer in Digital Setup - Technical Setup remains Greyed(fade) unable to select if my Logitech K400 plus USB transmitter is plugged-in.
5. Location status appears everytime TV is rebooted.
6. General Satellite gives an error: No signal. Please check your antenna connection. This happens if in sequence:
a. Reboot from home or Digital(DVB-T)
b. TV starts in digital(DVB-T).
c. General Satellite is selected after Digital(DVB-T)
and... can be solved only if Digital is selected again and then go back to General Satellite.
7. Deleted Satellite channels re-appear themselves automatically.
8. Satellite Channels re-arrange themselves automatically if TV is Soft-reboot within Digital(DVB-T).
9. TV remains Active in Network even if powered OFF with Remote Control.
10. Using Favourites lists in both Digital and Satellite and browsing with Remote Control PROG +/- , mixes channels from these different tuners. Digital Favourites1 go by themselves to Satellite Favourites1.
Now what came back:
1. 20 seconds TV freeze but till now only at Settings Menu - Digital Adjustments.
2. TV dimming and un-dimming when subtitles appear in dark schenes of movies.
What seems to be solved:
I completed this update this morning!
Netflix is no longer working for me as when I try to open the app the following message appears:
Netflix has encountered an error. Code: ui-800-3
Hi there
Ive seen this reported to. Sony is also aware...
Can you please tell me what model tv and what country you are from?
Hi Quinnicus,
Thank you for your prompt response.
TV Model: Sony 49x8309c
Country: Northern Ireland
Can you confirm if you already had a working netflix account before the update? Or are you trying to create one?
Can you also confirm if your TV is connected to the Network properly?
Also, see:
What ISP are you with? And what is the make/model of your router?
Sorry for the 100 questions. Im just gathering information.
