Just purchased the KDL43WF663BU as a bedroom TV. After purchasing online I read thru specs and features and was alarmed to see NO under Netflix streaming. Can anybody tell me if this TV is Netflix capable. Thanks.
Hi Alrobo,
Well, to my knowledge there's a Netflix button on the remote - so I would assume that it can handle Netflix.
Just give it a try.
Hi Peter.
I didn't have the TV when I posted, I was looking at the specifications online. I have the TV now and as you say there is a Netflix button and it works fine. Thank you.
