Hi, I have a KD 43XD8077 and Netflix has stopped working. I can select the app it opens up and shows previews but if I go to play anything it says having trouble playing this title. It then shows error tvq pb 101 5.6.1. I have tried reinstalling the app and also resetting the tv. Help!
Hi Chrisanta81,
Please try the following:
Go to "Home > settings > apps > Netflix"
Force the app to stop and clear the cache.
After this the Netflix should work again.
(This is how I fix Netflix on my XD80 :))
