We have also been experiencing this issue for a few weeks, very frustrating. Looking forward to a fix as the software update didn’t resolve it for us
I'm having the same issue on my 55x8005c running the latest update from Sony.
Hi
I've faced the same problem and made small app to solve it. All the application do is force stop old instance of Netflix and start new one. It's open source. You can compile it on your own or use my APK.
1. Install app on your SONY TV
2. Since now start NETFLIX via new N icon
3. If you are using NETFLIX remote button remap it with netflixbuttonchanger
4. Please tell me if it helps
netflixrelauncher_1_0.pngNetflix Relauncher 1.0
I have two Sony TV’s only one of which has this problem, KD-55XD8599. All software is up to date. The lastest solution received from Sony is to follow this link and carry out the following
https://www.sony.co.uk/electronics/support/televisions-projectors/articles/00201618
Just like smartphones and tablets, if you have too many apps open, you can experience low system memory symptoms on Sony's Android TV. This stops the system from running as efficiently and may cause performance issues.
It’s recommended to free up memory by closing apps running in the background or restarting the TV.
To close running apps, please follow the steps below:
There were only two apps open, Netflix and Prime. We always exit the apps when we finish watching so can’t understand why the apps where still running. Is this the problem, apps not closing down? So far it appears to be working. I’m waiting for a response from Sony to my question if this is regular procedure I’ll have to carry out.
