TV is a KD65X8509 (android TV), connected to a Sony RHT-G11 sound system. 3 inputs to the RGH-G11, for BlueRay, XB1 (CEC-Tray), and Sky+HD box.
The problem I have is that one of these inputs (player 2 on HDMI4) doesn't display correctly on the INPUT SELECTION option:
http://www.flickr.com/photos/tarbat/24042069791/sizes/o/
Nor on the HOME screen:
http://www.flickr.com/photos/tarbat/24016566762/sizes/o/
It's correctly detected in the Bravia Sync device list:
http://www.flickr.com/photos/tarbat/24098585326/sizes/o/
And also correctly displays if I select Bravia Sync inputs from the ACTION MENU
http://www.flickr.com/photos/tarbat/24124679765/sizes/o/
Any ideas how to force the INPUT SELECT and HOME SCREEN to correctly display the Bravia Sync (CEC) name for this input?
EDIT: Possibly connected to item 15 on the "known issues" list, so can this issue be added to that one, thanks. http://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2047983#M35186
Fixed using the Ireland/EU firmware.
Interesting indeed. Thank you for confirming this. Hopefully this replicates over to the long awaited for UK firmware release in Feb.
Unfortunately, after a reboot of the TV, the problem is back 😞
Well that was silly then.
Seriously, thats a big bummer really.
@chrgray @Anonymous Mine also does this, it ocassionaly marks th Sky + HD as 'player_2' other times is OK
@chrgray wrote:Unfortunately, after a reboot of the TV, the problem is back 😞
If you reset your AV Amp to factory defaults it should fix it. This worked for me.
So, this does seem to be almost fixed using the EU/Ireland firmware v3.169. On the old UK version of the firmware, I could NEVER get the inputs to get their CEC labels correctly. With the v3.169, the inputs do all get their names correctly, but it sometimes takes some time after a re-boot for them to appear. Once they appear correct, they stay correct.
So, definate progress, which hopefully will carry over to the UK firmware whenever that gets released.
I have exactly the same problem with KD-55S8505C in UK. Should I switch to the EU firmware? Thanks.
