Why will my tv not connect to youview
@Babydee2806 wrote:Why will my tv not connect to youview
What model of TV is it?
what steps did you take to set it up?
Has it worked in the past, or is this a new setup, or what?
What are you doing to try and get the connection?
Are you wired or wifi?
What error message do you get?
Do you have anything at all on the TV that is successfully connecting to the internet?
