Hi my KD65A85BU won’t switch on it clicked off now nothing, the led in the middle flashes in a sequence of 4 in RED , and Sony only work Monday to Friday ,any one had this problem.?? .And it’s only 2 weeks old .
Sounds like a technical issue. Have you disconnected the TV from mains for some minutes?
Maybe this helps to solve the issue.
If not, please get in touch with your dealer.
Hi yes left off overnight ,just the same have contacted curry’s and they say go to Sony .
thanks anyway
Michael
