My KDL-55W755C has start to get so slow, why is that?
profile.country.SE.title
Fredand44
Member
Hello,
For a couple of years ago we bought a KDL-55W755C.
It has start to get slow in the interaction especially during start up, it does not respond from the remote, it seems like it is trying to load some recommendations and such, I do not know actually what it is going on inside.
The software is updated and I have removed all google accounts. Some times we feel that we have to pull the plug and start it up from scratch after not responding for a couple of minutes. Then it starts a bit faster. But after a couple of days, so slooooow when we try to interact with it.
Any ideas?
Best regards
Fredrik
5 REPLIES 5
profile.country.IT.title
rooobb
Expert
It is a 2015 TV model so little more than 2 years ago .. there are a bit of tips in the internet to make an Android TV faster but it is still an old soc
Fredand44
Member
Hello,
You said something about tips on internet, do you got some links?
Best regards
Fredrik
rooobb
Expert
Google is your best friend... you can start from here https://youtu.be/SW1S68w4Uvc https://youtu.be/w3ZnPq06jjA
We show you how to disable the Samba Interactive TV notification on Sony TVs with Android Nougat 7.0 update, & also how to speed up Android TV by disabling apps & limiting the number of background processes. ======================== **Click Below to SUBSCRIBE for More Reviews, Sneak Peeks & Tips:
We demonstrate 11 Sony TV tips & tricks to speed up the Google TV performance, using a Sony A90J Master Series OLED television as an example. Tips include: 0:00 Apps-only mode 0:53 Get to apps faster 1:34 Skip home screen 2:05 Quick settings 2:44 Reduce data transmission 3:44 Clear cached data ...
profile.country.DK.title
stampe
New
Hej har samme problem med mit 2016 android tv.  TÆnker ale med android sony tv som er ældre har dette problem.  Der er 1000 som skriver om det på nettet. Men ingen ok løsninger.  Jeg har selv 3 med samme problem og 8 venner med samme problem .  >>Det hjælper ikke at reset tv andet i kort tid .   Tv burde køre som nyt efter reset men det gør det heller ikke.   Kan ikke lade være med at tænke er det sony som tager røven på os .  Tvinger folk til at købe nyt.    De kommer ikke med en god forklaring på problemet  !!!!
Fredand44
Member
Hej
I vårar fall kom ett hyfsat bra erbjudande från Telia som vi nappade på. Så nu har vi en fristående box som använder tv:n som skärm. Så nu kör jag allt via boxen istället. Lite sunkig lösning, men tv:ns livstid verkar ha förlängts med några år. Boxen är alltså mycket snabbare än "datorn" i tv:n.
