When playing MKV internally (both from usb and stream) i get wrong color range.
Blacks look grey, and i don't get the option to change color range on internall apps.
Sony x950H
Try downloading VLC from Google Play and check if the same happens. MKV files have dodgy support. I believe the manual specifically says their functionality isn't 100% guaranteed.
Win_88
