Hi.
Is there a way to get rid of "extra" subtitles when playing an MKV file on my Bravia? Turning off subtitles in TV settings does not do this, whereas on a laptop it does not show them.
Thanks for any tips!
If your BRAVIA is an Android TV..., should search through the Settings of the App you use to play them...
If you use Video App try also VLC or Nova Player...
