I got the new firmware (PKG6.3626.0521EUA) a few days ago.
Since then, every time I adjust the sound or change the channel, after approximately 10 seconds, the sound will disappear completely for about a second.
I have the TV connected to my STR-DN1040 and there was no issue before the update.
Hi Glen,
You can try the following:
[Settings] ► [Display Sound] ► [Audio Output] ► Last setting in this screen: [Pass through mode]
[Settings] ► [Storage and reset] ► [Internal storage] ► [Cache] ► [Clear]
Press and hold the Power button on the remote for 10 seconds, the TV will restart.
Win_88
Hi glenstrup,
I'll just see if I can find any help regarding this. In the meantime though, maybe another community member might have some ideas.
Thanks,
Pascale
Hi Glen,
Win_88
