Last night I experienced something new (and frustrating)...
I was watching a 4k video and the colour looked way off so I thought I'd check the settings. I was right, the settings were completely different to what they should have been, and they were locked i.e. I was unable to make any changes. As soon as I stopped playing the file they changed back to were they should have been. I tried playing another couple of files (4k and 1080p) and the settings were correct AND I was able to change them.
I've not bothered updating the TV with the last couple of updates, but I'm updating it now to see if that makes a difference.
Has anyone else experienced this?
Hi there
Have you enabled Auto Picture mode by any chance? As that is what Im guessing at this stage.
How did it go after the FW update?
