First thing is can it be done and if so which ones,the manual on this site says it can be done with my tv but have tried 3 pairs with no luck,just keeps searching and don't pick them up.
Any help would be great or even the best make to get which people have tried and worked.
Thanks.......Sony 49x8309c..........
you can't pairing between TV and BT Headphones, TV hasn't the necessary A2DP Profile for this...
Manolo
Hi there,thank you very much for your fast reply,i have looked at the links to Amazon that sells the item that fits into your t.v so you can add them.
Thanks again.
Have you find an adaptor Headphones > Bluetooth I presume...
Manolo
Well there is a few on ebay only £12 so sent person a message to see if i can leave the item turned on all the while as it will be behind t.v and hard to get to to keep turning off and on.
