Do not install the new update, it stops the remotes tv button from working, there is no rectification date from Sony
@TheGOAT wrote:@TonyKD49X8309Cwhat TV model are you speaking about?
Hi @TheGOAT The clue is in the user name 😁
Hey @TonyKD49X8309C try this workaround: Use the input select button to open the application or open the application from the TV home screen apps overview.
