I had kodi on my xd93 but ended up deleting it
Now everytime I try and download it I get an install error code 504
I ve tried signing in and out my Google account and clearing the Google play data, but nothing seems to work, it just won't install
Any ideas?
Hi Matt,
Welcome to the community.
Make sure you have the latest sytem update installed. You can follow the instructions here.
Then once you have and if Kodi still doesn't download, it might be best to do a factory reset on your TV. You can find detailed instructions on how to do this here.
Try to download this again after the factory reset, and let us know how you get on.
Thanks,
Pascale_F
