Keep loosing ITV Hub while watching
SOLVED
profile.country.GB.title
Thjhe2
Explorer
I have a KD-55AG9 which keeps loosing ITV Hub while watching. When it looses it it says something went wrong try again later or it asks me to sign in and gets into a muddle. Has anybody else had this problem or is it a problem with the TV which is only a month old.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.DE.title
Peter_S.
Genius
Are you running the latest software on your TV?
Is the network connection OK? Maybe run a network diagnosis.
1 REPLY 1
Peter_S.
Genius
